[Qgis-tr] Original Transifex translation files
Jürgen E. Fischer
jef at norbit.de
Tue Oct 26 09:35:45 PDT 2021
Hi Stefano,
On Tue, 26. Oct 2021 at 17:10:22 +0200, Stefano Campus wrote:
> Hi, I have seen that the new version of the GUI for QGIS 3.22 has been
> uploaded to transifex.
> The following versions are now available for translation and review:
> qgis-application
> release-3-16
> release-3-20
> release-3-22
> Thanks to the features of Transifex, the Italian team continues to update
> all versions of QGIS.
> I wanted to ask you the courtesy to let us know when the older versions
> will be removed from Tx, so that we can download the .ts file, transform it
> into .qm and upload it with a Pull Request in the GitHub repository.
Which github repository do you mean? The qgis repo doesn't contain .qm files.
Those are created from the .ts files that are in the repo on build.
And the .ts files are updates from transifex on release already. From the
branches repo on point releases and into master on minor and major release just
before the new release branch is created. At that point a also a corresponding
transifex branch is created.
release-3-20 doesn't need to be updated anymore as there are no more builds of
3.20. Any translation changes after it's last release are more or less
useless (just like commits to the repo).
I guess the feature to delete branches is still broken in the transifex
interface and will still have to ask transifex support to delete it.
Oh, I never tried to delete transifex branches with the client. I'll check
that first. I that works, I could just delete the previous release's branch
via tx just like creating the new one.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20211026/428f4051/attachment.sig>
More information about the Qgis-tr
