[Qgis-tr] About the resources for QGIS Desktop on Transifex
    DelazJ
    delazj at gmail.com
    Fri Dec  6 06:14:13 PST 2024
Hi Jürgen,
Le 6 décembre 2024 12:02:10 GMT+01:00, "Jürgen E. Fischer" <jef at norbit.de> a écrit :
>Hi Harrissou,
>On Fri, 06. Dec 2024 at 11:29:18 +0100, DelazJ via Qgis-tr wrote:
>> Thanks for reporting.
>> Removal of old releases has to be done manually, so just an oversight here. Underway!
>Does that work now?  Did you try?  Because before that always had to be done
>via transifex's support.  Trying to delete the resource would just get stuck
>somewhere and silently fail.
Yes. I did it the last time for 3.30 and at least 3.32. It however takes a loooong time, but not that long. I wonder if it doesn't get stuck this time. Is that you who locks translation to 3.38? Today? In which case I could assume that it is what interrupted the deletion process... And it could be worth proceeding again.
Harrissou
>> qgis_en.ts is a misnamed file for 3.40. @jef-n could it just be renamed in
>> Transifex or are there some other logic (that would have failed) in play in
>> QGIS repository?
>Done.  The slug was already release-3_40-qgis-application just the name was
>qgis_en.ts (automatically assigned by transifex when pushing).
>Jürgen
More information about the Qgis-tr
