[Qgis-tr] About the resources for QGIS Desktop on Transifex
Jürgen E. Fischer jef at norbit.de
Fri Dec 6 03:02:10 PST 2024
Hi Harrissou,
On Fri, 06. Dec 2024 at 11:29:18 +0100, DelazJ via Qgis-tr wrote:
> Thanks for reporting.
> Removal of old releases has to be done manually, so just an oversight here. Underway!
Does that work now?  Did you try?  Because before that always had to be done
via transifex's support.  Trying to delete the resource would just get stuck
somewhere and silently fail.
> qgis_en.ts is a misnamed file for 3.40. @jef-n could it just be renamed in
> Transifex or are there some other logic (that would have failed) in play in
> QGIS repository?
Done.  The slug was already release-3_40-qgis-application just the name was
qgis_en.ts (automatically assigned by transifex when pushing).
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20241206/f29fba5b/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20241206/f29fba5b/attachment.ksh>
More information about the Qgis-tr mailing list
