[Qgis-tr] Mass text replacement
Péter Báthory bathory86p at gmail.com
Tue Feb 10 02:44:42 PST 2026
Hi Stefano,
> Is it possible to perform these mass replacements in Transifex?
Yes, Transifex provides an excellent interface for mass replacement. I did
something similar a few weeks ago in the Hungarian translation.
Search for the expression you want to replace, check the Select all box,
and then you will find the "Find and replace translation strings" box in
the panel that opens on the right. The replacement is case sensitive, so
run all replacements with a capital letter as well. By default, the
operation only replaces whole words, but this can be changed using the
checkbox below the input fields.
Best regards,
Péter
Stefano Campus via Qgis-tr <qgis-tr at lists.osgeo.org> ezt írta (időpont:
2026. febr. 9., H, 23:40):
> Transifex Webtranslation page for QGIS is on
> https://www.transifex.com/qgis/
> Good evening everyone, After years of "community" translations, we have
> gained some experience in bringing many expressions back to a single,
> unambiguous translation.
> What we would like to do is a massive replacement some words inside
> already translated strings.
> Is it possible to download the file from Transifex to edit it, perhaps
> with Qt Linguist, make the mass changes and then re-upload it to Transifex?
> Thank you very much for your attention.
> Stefano Campus
> QGIS-Translators mailing list
> Qgis-tr at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20260210/eed558a4/attachment-0001.htm>
More information about the Qgis-tr mailing list
