[QGIS-trac] Re: [Quantum GIS] #554: identify - some varchar column
displayed instead of the key column
Quantum GIS
qgis at qgis.org
Sat Aug 2 04:55:32 EDT 2008
#554: identify - some varchar column displayed instead of the key column
Reporter: tutey at o2.pl | Owner: timlinux
Type: bug | Status: assigned
Priority: major: does not work as expected | Milestone: Version 1.0.0
Component: Vectors | Version: 0.8
Resolution: | Keywords:
Platform_version: Ubuntu Dapper | Platform: Debian
Must_fix: Yes | Status_info: 0
Changes (by timlinux):
* status: new => assigned
* owner: nobody => timlinux
Comment:
Hi
I believe this is in fact intended behaviour as the QgsVectorLayer author
implemented it :
207 // If fldName is provided, use it as the display field, otherwise
208 // determine the field index for the feature column of the identify
209 // dialog. We look for fields containing "name" first and second
for
210 // fields containing "id". If neither are found, the first field
211 // is used as the node.
Unless I am completely misunderstanding the issue...
One thing I did notice is that when I tried to change the display field to
'cat' using the test dataset provided above, the display field only showed
'name' as an option. Perhaps we need to allow display field to be set to
non string fields. I will investigate futher.
In the meantime please clarify any misunderstanding I have - I would like
to move this ticket from bug to enhancement and from status major to
enhancement and remove must fix annotation. I await your feedback.
Regards
Tim
Ticket URL: <https://trac.osgeo.org/qgis/ticket/554#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
