[QGIS-trac] Re: [Quantum GIS] #554: identify - some varchar column displayed instead of the key column
Quantum GIS qgis at qgis.org
Sat Aug 2 05:21:53 EDT 2008
        Reporter:  tutey at o2.pl                       |         Owner:  timlinux
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.0
       Component:  Vectors                           |       Version:  0.8
      Resolution:  fixed                             |      Keywords:
Platform_version:  Ubuntu Dapper                     |      Platform:  Debian
        Must_fix:  Yes                               |   Status_info:  0
Changes (by timlinux):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Hi
 Ok another update on this. I found the problem causing display field combo
 box issues in vector props dialog (applied as r8977. For me the issue is
 resolved now following this procedure:
 - load supplied 'wrong key' dataset
 - open vector properties
 - select general tab
 - select 'cat' for display field
 - close vector properties
 - use identify tool to select a feature
 Result is shown in the attached screenie
 (https://trac.osgeo.org/qgis/attachment/ticket/554/ticket_554.jpeg).
 I'm marking this ticket as fixed now. Please reopen if it does not work
 for you.
 Regards
 Tim
Ticket URL: <https://trac.osgeo.org/qgis/ticket/554#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
