[QGIS-trac] Re: [Quantum GIS] #1176: Transverse mercator south orientated projections not supported
Quantum GIS qgis at qgis.org
Thu Aug 7 20:29:15 EDT 2008
        Reporter:  halfhaggis                       |         Owner:  nobody
            Type:  bug                              |        Status:  closed
        Priority:  minor: annoyance or enhancement  |     Milestone:  Version 1.0.0
       Component:  Projection Support               |       Version:  HEAD
      Resolution:  invalid                          |      Keywords:
Platform_version:                                   |      Platform:  Debian
        Must_fix:  No                               |   Status_info:  0
Changes (by timlinux):
  * priority:  major: does not work as expected => minor: annoyance or
               enhancement
  * status:  new => closed
  * resolution:  => invalid
Old description:
> I need to project maps in South Africa, where we use the Hartebeesthoek
> projections. These are based on transverse mercator south orientated.
> These projections are not supported, making it impossible for me to carry
> out any measurements etc. This effectively makes the application useless
> in most cases where such projections are needed.
> It appears to be related to the fact that proj4 lacks support for south
> orientated projections.
> Is there some way around this? Is there a solution using PostGIS,
> perhaps? If so, it should be highlighted for new users, with clear
> instructions on how to implement it.
New description:
 Is there some way around this? Is there a solution using PostGIS, perhaps?
 If so, it should be highlighted for new users, with clear instructions on
 Lastly there are quite a number of South orientated coordinate reference
 systems included with the QGIS database and it certainly does support
 them.
 Regards
 Tim
Comment:
 Hi
 You can define custom projection definitions using the tool provided under
 the tools menu. Also your terminology is I think incorrect - Hartebeeshoek
 is a datum describing the spheroid. AFAIK Surveys and Mapping began
 phasing out the use of the Hartebeeshoek datum around 9 years ago, in
 favour of the WGS84 datum.
 Regards
 Tim
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1176#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
