[QGIS-trac] Re: [Quantum GIS] #1079: on the fly projections do not work
Quantum GIS qgis at qgis.org
Thu Aug 21 07:46:49 EDT 2008
        Reporter:  pcav                                       |         Owner:  mhugent
            Type:  defect                                     |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.0.0
       Component:  Projection Support                         |       Version:  HEAD
      Resolution:  fixed                                      |      Keywords:  srs.db datum
Platform_version:                                             |      Platform:  All
        Must_fix:  Yes                                        |   Status_info:  1
Comment (by neteler):
 Replying to [comment:10 leolami]:
 > Hi all,
 > the problem seems solved, I tested using a projection like Gauss Boaga
 standard (EPSG code=3003)
 > +proj=tmerc +lat_0=0 +lon_0=9 +k=0.9996 +x_0=1500000 +y_0=0 +ellps=intl
 +units=m +no_defs
 Note that this string is incomplete. It lacks +towgs84=...
 See also #377 and especially #418. The problem persists and needs to be
 solved.
 Markus
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1079#comment:11>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
