[QGIS-trac] Re: [Quantum GIS] #1079: on the fly projections do not work
Quantum GIS qgis at qgis.org
Thu Aug 21 07:52:37 EDT 2008
        Reporter:  pcav                                       |         Owner:  mhugent
            Type:  defect                                     |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.0.0
       Component:  Projection Support                         |       Version:  HEAD
      Resolution:  fixed                                      |      Keywords:  srs.db datum
Platform_version:                                             |      Platform:  All
        Must_fix:  Yes                                        |   Status_info:  1
Comment (by msieczka):
 Replying to [comment:10 leolami]:
 > But if I create a custom projection like this and I set it as the
 default projection  when I
 > load the GRASS layer I see that QGIS associates to the layer the
 standard projection:
 > +proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs
 > but I remember that before QGIS readed the projection with parameters
 like the same projection
 > withot them and it associated to the layer the standard Gauss Boaga
 projection (EPSG code=3003)
 Please post a sample GRASS location with a single layer for testing.
 Maciek
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1079#comment:12>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
