[QGIS-trac] [Quantum GIS] #1447: gaps in lines for outline width <
0.26
Quantum GIS
qgis at qgis.org
Sun Dec 7 15:20:30 EST 2008
#1447: gaps in lines for outline width < 0.26
Reporter: msieczka | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.0.0
Component: Graphics | Version: HEAD
Keywords: | Platform_version:
Platform: All | Must_fix: Yes
Status_info: 0 |
Current default 0.2 outline is not wide enough when neither "Fix
problems..." nor "Make lines appear less jagged..." are set in rendering
options - see the attached screendumps.
A minimum outline width at which the issue is gone in all cases that I
checked is 0.26. Is this a feature or a bug? If a feature I think QGIS
should default to 0.26 instead for a workaround.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1447>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
