[QGIS-trac] Re: [Quantum GIS] #1447: gaps in lines for outline
width < 0.26
Quantum GIS
qgis at qgis.org
Sun Dec 7 22:25:29 EST 2008
#1447: gaps in lines for outline width < 0.26
Reporter: msieczka | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.0.0
Component: Graphics | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 0
Comment (by smizuno):
I have found that the width setting to use depends on the operating
system/Qt as the reported screen resolution typically is 96dpi, but might
not be on some platforms. The value 0.26 is approximately the result of
25.4mm/96dpi (the size of one pixel). Also, as the width is increased the
line will become solid, but with an increasing number of double pixels.
This is normal Qt behavior.
I filed ticket #1238 to have more control because of this behavior.
There is a Qt special value of 0.0 which draws one pixel width regardless
of the device. This is fine for use on screen, but is probably too thin
for print.
I believe that any given fixed setting will not be satisfactory to many
users. This is an argument for making the default width user settable.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1447#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
