[QGIS-trac] Re: [Quantum GIS] #1351: WMS and DB connections should have a per connection proxy enable/disable option
Quantum GIS qgis at qgis.org
Tue Dec 9 04:58:29 EST 2008
option
        Reporter:  neumann                           |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.0
       Component:  WMS                               |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  Debian
        Must_fix:  No                                |   Status_info:  0
Comment (by neumann):
 alternatively to my suggestion above it might be better to introduce a
 lists of IP-Adresses/Server names which should not use the global proxy
 settings. QGIS could use a pattern matching to see if the WMS request
 starts with these addresses/servernames and if not use the proxy.
 This would perhaps be the easiest way to distinguish local from remote
 systems, where local machines shouldn't use the proxy and remote machines
 should. One could extend the proxy tab in the QGIS Options dialogue with a
 "proxy exceptions" list-management option where one can add, edit and
 remove servers, similar to the WMS/WFS dialogues.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1351#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
