[QGIS-trac] Re: [Quantum GIS] #996: Re: [Quantum GIS] #996: QGIS corrupts JPEG2000 colors
Quantum GIS qgis at qgis.org
Wed Dec 10 17:17:50 EST 2008
        Reporter:  coatman                           |         Owner:  nobody
            Type:  defect                            |        Status:  reopened
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.1
       Component:  Rasters                           |       Version:  HEAD
      Resolution:                                    |      Keywords:  kakadu raster
Platform_version:                                    |      Platform:  OS X
        Must_fix:  No                                |   Status_info:  0
Comment (by warmerdam):
 Replying to [comment:40 Coatman]:
 > Hi Frank,
 > Thanks for your suggestion.
 > < A focused GDAL ticket should likely be filed on this. >
 > I would appreciate it if you would please suggest where to go to file a
 focused GDAL ticket.
 At the risk of being flippant, a focused GDAL ticket should be filed in
 the GDAL bug tracker.  (http://trac.osgeo.org/gdal).
 It needs to demonstrate the problem with GDAL utilities or some small
 sample program using the API.    As there is already a ticket languishing
 on the JasPer issue there is no point in filing another.  If you were to
 file one on the JP2KAK problem, it would need to be based on something
 reproducable with GDAL utilities (ie. gdal_translate).  It appears from
 the comments above that this is not so easy.
 I do think the color mapping stuff is a promising angle, though it isn't
 particularly clear to me why it would work for gdal_translate, and not for
 qgis.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/996#comment:42>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
