[QGIS-trac] Re: [Quantum GIS] #1452: crash loading big shapefile
Quantum GIS
qgis at qgis.org
Wed Dec 17 10:48:43 EST 2008
Reporter: msieczka | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.0.0
Component: OGR Layer support | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: Debian
Must_fix: Yes | Status_info: 0
Comment (by hdus):
Replying to [comment:2 msieczka]:
> Replying to [comment:1 hdus]:
> > Works for me. I just loaded a shape with size of 1.2GB and more than
1000000 polygons without any problems regardless whether I use on the fly
projection to WGS84 or not. Did you check your data?
> The data is OK AFAICT. I can easily process it with OGR tools,
export/import in GRASS. Will soon try rendering with MapServer and I'll
post the result if I remember to.
> Interesting - the Shapefile crashes whole Xorg (!!!) if "Fix
problems..." is set ON in Options>Rendering, and only crashes QGIS alone
if the option is set OFF.
That's the difference to my attempt. I had swiched off this option. Now I
switched "Fix problems ..." on, but every works fine for me.
> I can't share the data in public. It's for sale. I could share it with
an interested QGIS developer in private if he promises not to redistribute
it.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1452#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
