[QGIS-trac] Re: [Quantum GIS] #967: CRS of a new shapefile doesn't match CRS of the project
Quantum GIS qgis at qgis.org
Mon Oct 27 15:59:44 EDT 2008
        Reporter:  msieczka                          |         Owner:  nobody
            Type:  defect                            |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.0
       Component:  Projection Support                |       Version:  HEAD
      Resolution:  invalid                           |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  Yes                               |   Status_info:  0
Changes (by homann):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 You can select if the CRS of the new layer should be the global default,
 the project CRS or if it should ask for it. You do the selection in
 Settings -> Options...
Ticket URL: <https://trac.osgeo.org/qgis/ticket/967#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
