[QGIS-trac] Re: [Quantum GIS] #946: New Project Should Get
Projection of First Loaded Layer
Quantum GIS
qgis at qgis.org
Mon Oct 27 16:04:53 EDT 2008
#946: New Project Should Get Projection of First Loaded Layer
Reporter: driggs | Owner: nobody
Type: defect | Status: closed
Priority: major: does not work as expected | Milestone: Version 1.0.0
Component: Projection Support | Version: HEAD
Resolution: wontfix | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Changes (by homann):
* status: new => closed
* resolution: => wontfix
Comment:
This is the intended behaviour.
Considering what happens if you first set the project CRS and then start
adding layers. if the layer you add first is not teh same as you just set,
you have to reset it again. Minimizing side effects, we should stick with
the current behaviour.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/946#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
