[QGIS-trac] Re: [Quantum GIS] #1641: trunk r10595 fails to build at
parsing SIP files for 'gui'
Quantum GIS
qgis at qgis.org
Sun Apr 19 08:15:42 EDT 2009
#1641: trunk r10595 fails to build at parsing SIP files for 'gui'
Reporter: msieczka | Owner: nobody
Type: bug | Status: reopened
Priority: critical: causes crash or data corruption | Milestone: Version 1.1.0
Component: Build/Install | Version: HEAD
Resolution: | Keywords:
Platform_version: amd64 | Platform: Debian
Must_fix: Yes | Status_info: 0
Comment (by wonder):
Builds fine on my box too.
The error suggests that the problem is in the PyQt4 sip file so I suggest
you to report this to PyQt4 developers. In meanwhile you can try some
other PyQt4 version to see whether it helps. What version do you use? Have
you done any upgrade of it recently?
And I recommend you to close the bug as it's probably unrelated to qgis.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1641#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
