[QGIS-trac] Re: [Quantum GIS] #1641: trunk r10595 fails to build at
parsing SIP files for 'gui'
Quantum GIS
qgis at qgis.org
Sun Apr 19 09:54:24 EDT 2009
#1641: trunk r10595 fails to build at parsing SIP files for 'gui'
Reporter: msieczka | Owner: nobody
Type: bug | Status: reopened
Priority: critical: causes crash or data corruption | Milestone: Version 1.1.0
Component: Build/Install | Version: HEAD
Resolution: | Keywords:
Platform_version: amd64 | Platform: Debian
Must_fix: Yes | Status_info: 0
Comment (by jef):
Replying to [comment:4 wonder]:
> The error suggests that the problem is in the PyQt4 sip file so I
suggest you to report this to PyQt4 developers. In meanwhile you can try
some other PyQt4 version to see whether it helps. What version do you use?
Have you done any upgrade of it recently?
I would first check if it's a Debian testing problem or maybe even just a
local installation problem. As it builds fine on both sid and lenny.
> And I recommend you to close the bug as it's probably unrelated to qgis.
That was my point in closing the bug - it even builds fine on Windows, so
this doesn't seem to be any qgis problem.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1641#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
