[QGIS-trac] Re: [Quantum GIS] #1875: A few problems with crs
definitions with TOWGS parameters
Quantum GIS
qgis at qgis.org
Sun Aug 16 18:39:51 EDT 2009
#1875: A few problems with crs definitions with TOWGS parameters
Reporter: lutra | Owner: homann
Type: bug | Status: closed
Priority: critical: causes crash or data corruption | Milestone: Version 1.2.0
Component: Projection Support | Version: HEAD
Resolution: fixed | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Comment (by lutra):
Replying to [comment:28 homann]:
> Remove the +damtum=WGS84 from proj B, and test.
[[BR]]
Hi Homann,
If I remove "+datum" from B) the result is the same described earlier in
this ticket (see attached files, one defined with +towgs, the other
without but also without +datum): the two layer align correctly with OTFR
"on" and with certain crs defined for the project. The difference between
aligning or not seems to depend if in the project crs are defined the
+towgs/+datum/+ellps parameter(s). For example they align if the project
has epsg 3003 but not if the project has epsg 4326.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1875#comment:29>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
