[QGIS-trac] [Quantum GIS] #2170: spatialite problems with reserved
word column name
Quantum GIS
qgis at qgis.org
Tue Dec 1 11:51:58 EST 2009
#2170: spatialite problems with reserved word column name
Reporter: Barryrowlingson | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.4.0
Component: Data Provider | Version: HEAD
Keywords: | Platform_version:
Platform: Linux | Must_fix: No
Status_info: 0 |
I have a spatialite table with a column called 'UPDATE'. Loading into Qgis
causes problems accessing the attributes. The attribute table comes up all
'ERROR', and querying points on the map cause error messages and the map
layer points to all disappear. Pretty reproducible.
Streams of these appear:
SQL: near "UPDATE": syntax error
Critical: SQLite error: SELECT ROWID, TYPE, SITECODE, DATE, UPDATE, [etc]
which looks like column names are unquoted and so reserved words for
column names will break stuff.
[This database was full of tricksy names, such as tables called "region-
code" and "stuff with spaces" that needed quoting and munging as I
converted it from mdb to spatialite. Thought I'd got 'em all!]
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2170>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
