[QGIS-trac] Re: [Quantum GIS] #2117: if units are in degrees,
map scale is wrong in print composer
Quantum GIS
qgis at qgis.org
Tue Dec 1 13:27:06 EST 2009
#2117: if units are in degrees, map scale is wrong in print composer
Reporter: pcav | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.4.0
Component: Printing | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Comment (by pcav):
I confirm:
- load a layer in 4326
- activate the print composer and add a map
- change the scale by hand (e.g. 250000)
- click outside the box where you input the scale
the value is changed
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2117#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
