[QGIS-trac] Re: [Quantum GIS] #2189: Map Server Export - POSTGIS data
Quantum GIS qgis at qgis.org
Sat Dec 5 09:10:11 EST 2009
        Reporter:  smccabe33                         |         Owner:  rduivenvoorde
            Type:  bug                               |        Status:  assigned
        Priority:  major: does not work as expected  |     Milestone:  Version 1.4.0
       Component:  Build/Install                     |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  Debian
        Must_fix:  No                                |   Status_info:  0
Changes (by rduivenvoorde):
  * status:  new => assigned
Comment:
 We escape all table and variable names to be safe for names using spaces
 etc ...
 BUT there is an ceveat there, see:
 http://www.postgresql.org/docs/8.4/interactive/sql-syntax-lexical.html#
 SQL-SYNTAX-IDENTIFIERS
 Quote:
 Quoting an identifier also makes it case-sensitive, whereas unquoted names
 are always folded to lower (!) case. For example, the identifiers FOO,
 foo, and "foo" are considered the same by PostgreSQL, but "Foo" and "FOO"
 are different from these three and each other.
 So I reckon you have tablenames which are NOT lowercase... ?
 Should we consider this a bug?
 We could NOT quote table and variable names? We cannot test for spaces etc
 in tablenames or so, because we do not parse the data/sql ourselves.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2189#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
