[QGIS-trac] Re: [Quantum GIS] #2023: attribute table fails to display all rows after editing vector layer
Quantum GIS qgis at qgis.org
Mon Dec 7 07:37:42 EST 2009
        Reporter:  stevehartley                      |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:
       Component:  Vectors                           |       Version:  1.3.0
      Resolution:                                    |      Keywords:  vector attribute layer
Platform_version:  2000 Pr SP4                       |      Platform:  Windows
        Must_fix:  Yes                               |   Status_info:  0
Comment (by stevehartley):
 Replying to [comment:1 lutra]:
 > I cannot replicate the problem here.
 > Can you please test the qgis-dev version (available via the osgeo4w
 installer) and report back?
 > If the problem is confirmed can you please post a sample data in order
 to make further tests? thanks.
 I still get the problem with 1.4.0 Enceladus.  The posted layer should
 display it.  Having played around with it some more, I've found out more
 about it.  The bug only occurs if you add an object, not when you delete
 or merely move one.  The number of objects the attribute table displays is
 linked to the number displayed in the map view according to the zoom
 level, i.e. if you zoom in so that n objects from the layer to be edited
 are shown on the map view, then add an object to the layer and save, the
 attribute table will display the first n+1 objects in the layer's list
 (not necessarily those shown in the map view).  Note this means that if
 the whole layer is shown in the map view when you add an object, then the
 table will display all the layer's objects, and you wouldn't know there's
 a bug.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2023#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
