[QGIS-trac] Re: [Quantum GIS] #2220: Reshape Features works
incorrectly with rings(?): shapes differs from postgis/spatialite
Quantum GIS
qgis at qgis.org
Wed Dec 9 12:41:36 EST 2009
#2220: Reshape Features works incorrectly with rings(?): shapes differs from
postgis/spatialite
Reporter: dr | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.4.0
Component: Digitising | Version: HEAD
Resolution: | Keywords: reshape features,ring
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Changes (by lutra):
* platform: Windows => All
* summary: Reshape Features works incorrect => Reshape Features works
postgis/spatialite
Comment:
Actually I noticed that the vector layer behaves differently if it is
postgis/spatialite or if is a shapefile.
After reshaping, the ring becomes a "part" (an island), then:
*) in postgis/spatialite the island is not selectable nor identifiable. If
you use the "select features" tool on the main polygon then it then
selects also the island. The identify tool doesn't work the same, as
identifying the main polygon do not highlight the island.
*) with shapefiles the resulting island is both selectable and
identifiable but only after saving the changes. Before saving changes the
island in not identifiable nor selectable, as in the above case.
By the way, is correct the ring become an island after reshaping the
polygon?
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2220#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
