[QGIS-trac] Re: [Quantum GIS] #2049: Choosing Move Item Content in the print composer override Lock Layers
Quantum GIS qgis at qgis.org
Wed Dec 9 15:27:01 EST 2009
        Reporter:  lucacasagrande                    |         Owner:  mhugent
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.4.0
       Component:  Printing                          |       Version:  HEAD
      Resolution:  wontfix                           |      Keywords:  printing
Platform_version:                                    |      Platform:  Debian
        Must_fix:  Yes                               |   Status_info:  0
Changes (by mhugent):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 This is intended. 'Lock layers' means only to lock the layers displayed in
 a composer map, not their appearance.
 Common use-case is this: you have 10 layers, but like to only display 2 of
 them in an overview map. So you set the 2 layers visible, add a composer
 map (as overview), select 'lock layers'. Then you go back to main map, set
 all 10 visible and add a second composer map in composer. Like that, you
 can have 2 composer maps displaying different layer sets (not layer
 styles).
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2049#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
