[QGIS-trac] Re: [Quantum GIS] #2234: fTools: Export to new projection
Quantum GIS qgis at qgis.org
Wed Dec 9 22:15:20 EST 2009
        Reporter:  dr                                |         Owner:  cfarmer
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.4.0
       Component:  Python plugins and bindings       |       Version:  HEAD
      Resolution:  fixed                             |      Keywords:  ftools,export,projection
Platform_version:                                    |      Platform:  Windows
        Must_fix:  No                                |   Status_info:  0
Changes (by dr):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:5 lutra]:
 > Replying to [comment:4 dr]:
 > > Are you doing step by step? When we set Set "ID" = '2' there is 1
 polygon at map canvas?
 > yes, and then the tool export a shapefile with only that polygon in the
 new projection. In fact if I add it to the canvas and enable otfr I can
 see the two shapes overlap perfectly.
 There is no problem at r12391.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2234#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
