[QGIS-trac] Re: [Quantum GIS] #2023: attribute table fails to
 display all rows after editing vector layer
    Quantum GIS
    qgis at qgis.org
    Thu Dec 10 13:19:42 EST 2009
#2023: attribute table fails to display all rows after editing vector layer
        Reporter:  stevehartley                      |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.4.0
       Component:  Vectors                           |       Version:  HEAD
      Resolution:                                    |      Keywords:  vector attribute layer
Platform_version:  2000 Pr SP4                       |      Platform:  Windows
        Must_fix:  Yes                               |   Status_info:  0
Comment (by stevehartley):
 Replying to [comment:5 lutra]:
 > Replying to [comment:4 stevehartley]:
 > >   What version Windows are you using?
 > qgis trunk under linux (and also under xp and vista in virtual machines)
 > > Can you try using Win 2000?
 > no
 > I would suggest you to make a clean install (remove any .qgis directory
 containing personal definitions) and/or check if you enabled the render
 caching in qgis options.
 Enable/disable render caching makes no difference.
 I've tried to clean install, removing OSGeo4 and .qgis directories and
 anything else I can find affected by qgis (including projects and shape-
 files), but still get the problem.  It seems that usage info is hidden
 somewhere on my machine, because when I open up a "clean" installation,
 the toolbars and layer panel are positioned as at the last save of a
 project (prior to attempting a clean install).  Any ideas?
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2023#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
