[QGIS-trac] [Quantum GIS] #2270: issues with "add ring" and "add
part" tools (in shapefiles)
Quantum GIS
qgis at qgis.org
Fri Dec 11 15:17:37 EST 2009
#2270: issues with "add ring" and "add part" tools (in shapefiles)
Reporter: lutra | Owner: mhugent
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.4.0
Component: Vectors | Version: HEAD
Keywords: | Platform_version:
Platform: Debian | Must_fix: Yes
Status_info: 0 |
tested on qgis trunk under linux.
a) open a polygon shape, choose a polygon and add a ring with the proper
tool. Toggle editing to save changes. The ring is not more a ring, it
become a "part". In fact, if you want to remove the just created
ring/part, you need to use the "delete part" tool instead of the "delete
ring" tool.
b) Select a polygon and try add a "part" that overlaps the selected
polygon, you'll get the message "New polygon ring not disjoint with
existing polygons" and the "part" in not added, but the "island added"
action always appear in the "Undo/Redo" stack.
c) For sake of consistency the "island added/delete" text in the undo/redo
stack should become "part added/deleted"
d) After all it seems that "parts" that do overlap with the main polygon
can exist (see http://gis-lab.info/share/10m-urban-area.zip and the above
bug), so, considered that qgis does not allow create such geometry, we
should always consider these layers as incorrect? After all (for example)
the "urban area" layer returns many errors when its geometry is checked.
It doesn't seems to happen with postgis or spatialite, just shapes, BUT,
if you create a ring in a postgis/SL polygon, then you save it as
shapefile and then add it to the canvas, instead of the ring you'll see a
part.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2270>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
