[QGIS-trac] Re: [Quantum GIS] #1989: v.distance should have radio
buttons, not checkboxes
Quantum GIS
qgis at qgis.org
Tue Dec 15 11:32:09 EST 2009
#1989: v.distance should have radio buttons, not checkboxes
Reporter: pcav | Owner: rugginoso
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.4.0
Component: GRASS | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Comment (by lutra):
The checkboxes make sense in the GRASS gui because in GRASS you can
specify more than one column name as the field is open.
In QGIS the field to specify the column name is a dropdown, but radio
buttons seems to be not available in qgis GRASS plugin.
Workaround:
1) replace the dropdown with a open field
2) make possibile to select more than one column name in the dropdown
3) introduce radio buttons in the plugin
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1989#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
