[QGIS-trac] [Quantum GIS] #2307: Edit widget not working correctly
( show first value instead of the correct one)
Quantum GIS
qgis at qgis.org
Mon Dec 21 09:28:48 EST 2009
#2307: Edit widget not working correctly ( show first value instead of the correct
one)
Reporter: pinux | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.4.0
Component: Vectors | Version: HEAD
Keywords: edit widget feature form | Platform_version: OSGeo4W Nightly Build
Platform: Windows | Must_fix: Yes
Status_info: 0 |
When I'm using the Feature form with the edit widget "Unique value" I'm
not getting the correct attribute of the feature. I'm getting the first
one that is in the list. I have the same problem with shapefile and
postgis. I have experienced the same problem even with the another widget.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2307>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
