[QGIS-trac] [Quantum GIS] #2309: vrt nodata is ignored when setting
min/max value by current extent
Quantum GIS
qgis at qgis.org
Mon Dec 21 20:18:35 EST 2009
#2309: vrt nodata is ignored when setting min/max value by current extent
Reporter: cgsbob | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.4.0
Component: Rasters | Version: HEAD
Keywords: | Platform_version:
Platform: Debian | Must_fix: No
Status_info: 0 |
To reproduce this bug, follow the following steps:
1) Extract and load the vrt file that is attached to this ticket
2) probe raster to see where the nulls are located.
3) zoom into a region that has some nulls.
4) In Raster Layer Properties>>Symbology, click on Current extent and then
the Load button. The vrt nodata value (-999) shows up in Min.
If you zoom into an area where there are no nulls, you get a correct
min/max value.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2309>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
