[QGIS-trac] Re: [Quantum GIS] #2294: help dialogs don't work on osx
Quantum GIS
qgis at qgis.org
Sun Dec 27 14:03:29 EST 2009
Reporter: epifanio | Owner: dassau
Type: bug | Status: reopened
Priority: major: does not work as expected | Milestone: Version 1.4.0
Component: Documentation and Help | Version: HEAD
Resolution: | Keywords: qgis_help
Platform_version: | Platform: OS X
Must_fix: No | Status_info: 0
Comment (by kyngchaos):
Massimo is using Qt 4.6 Cocoa, and at least the help app appears in front
for him, so that may be either a Qt version thing or Cocoa vs Carbon (I'm
using 4.5 Carbon).
Replying to [comment:8 jctull]:
> Also, the icon is low-resolution again in the dock and application
switcher. Not sure if this is related or not, but guessing it is.
Just qgis_help, or both? Didn't happen for me (xcode build), and Massimo
sent me a screenshot and qgis_help has a hires icon. Try a clean
configure and make?
> Is there a property item that makes an application icon not appear in
the dock? If the help application does not have an icon it would be ok.
Alternatively, it should have a unique icon. How is this handled on other
systems?
I pondered the possibility of a help icon or not showing it in the Dock.
It looks like other systems just use whatever the system does, ie no
special handling like was done with the original help app here. On
Windows, I assume it would show up as a generic command prompt app or
generic app in the start bar. On Linux, probably just nothing but the
window, unless the window system does something with CLI programs.
Not showing it in the Dock requires an application package, like the
original build, so the info.plist can have a certain key set.
An icon on OSX would also require the original app build for qgis_help, so
the plist can define a separate icon for it.
So, both ideas require an app package build.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2294#comment:9>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
