[QGIS-trac] [Quantum GIS] #1554: QGIS not properly recognizing/handling EPSG 2229
Quantum GIS qgis at qgis.org
Thu Feb 19 12:38:27 EST 2009
   Reporter:  j03lar50n                         |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:
  Component:  Projection Support                |            Version:  1.0.0
   Keywords:                                    |   Platform_version:  Kore
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
 Shapefile data with proper projection attribution (EPSG: 2229, NAD83 /
 California zone 5 (ftUS)) is not properly recognized when loaded into
 QGIS.
 My QGIS Options > CRS tab is set to 'Prompt for CRS' when layer is loaded
 that has no coordinate reference system. Tests have been run against other
 properly projected shapefiles and it appears this behavior is specific to
 EPSG 2229.
 Perhaps this issue arises from the definition of the .prj file - my data
 is coming from http://www.countyofsb.org/itd/gis/default.aspx?id=2802 I am
 also seeing a significant difference between the .prj files when defining
 the projection with fTools - but will address that issue with Mr. Farmer.
 Will be glad to attach any desired files. -joe
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1554>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
