[QGIS-trac] [Quantum GIS] #1555: A more efficient SQL query for uniqueness
Quantum GIS qgis at qgis.org
Thu Feb 19 17:03:06 EST 2009
   Reporter:  gjm                              |              Owner:  nobody
       Type:  enhancement                      |             Status:  new
   Priority:  minor: annoyance or enhancement  |          Milestone:
  Component:  Data Provider                    |            Version:  HEAD
   Keywords:                                   |   Platform_version:
   Platform:  All                              |           Must_fix:  No
Status_info:  0                                |
 The postgres provider, at times, runs a query on a table to see if a
 particular column contains unique values. This is done as part of choosing
 a suitable column to use as an index for that table. The SQL that does
 this uniqueness check is in the uniqueData() function in the
 qgspostgresprovider.cpp file. The SQL is:
 select count(distinct %1)=count(%1) from %2.%3
 where %1 is the column in question, %2 the schema name and %3 the table
 name.
 This counts the number of rows in that row almost twice. A potentially
 more efficient way to achieve the same outcome is with an SQL like this:
 select count(*) from (select %1 from %2.%3 group by %1 having count(*) > 1
 limit 1) as foo;
 This would return 0 or 1, depending if there were unique (or not) data in
 row %1.
 This needs a little bit of testing first to check that it does reduce the
 query time (I don't have the time at the moment).
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1555>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
