[QGIS-trac] Re: [Quantum GIS] #1472: Very slow shapefile editing, CPU usage maxes out. 1.0, on Intrepid AMD64
Quantum GIS qgis at qgis.org
Fri Jan 2 15:37:54 EST 2009
        Reporter:  FiReSTaRT                         |         Owner:  mhugent
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.1
       Component:  OGR Layer support                 |       Version:  1.0.0
      Resolution:                                    |      Keywords:  shp, shapefile, edit
Platform_version:  Ubuntu Intrepid 8.10              |      Platform:  Linux
        Must_fix:  No                                |   Status_info:  0
Comment (by FiReSTaRT):
 I'm positive that toggling editing, opening the attribute table and
 switching between highlighted features (with editing on) worked A LOT
 faster on 0.11 and without the huge CPU usage. With 0.11 I have been able
 to switch between various attribute table entries and edit them in real
 time.
 I just tested QGIS on a 32bit machine (P4 1.4, 1Gb) and also replicated
 every aspect of the problem. Ofcourse everything took even longer than on
 my regular 64bit machine (AMD QL-60 2x2.0Ghz, 4Gb).
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1472#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
