[QGIS-trac] Re: [Quantum GIS] #1472: Very slow shapefile editing, CPU usage maxes out. 1.0, on Intrepid AMD64
Quantum GIS qgis at qgis.org
Fri Jan 2 16:37:04 EST 2009
        Reporter:  FiReSTaRT                         |         Owner:  mhugent
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.1
       Component:  OGR Layer support                 |       Version:  1.0.0
      Resolution:                                    |      Keywords:  shp, shapefile, edit
Platform_version:  Ubuntu Intrepid 8.10              |      Platform:  Linux
        Must_fix:  No                                |   Status_info:  0
Comment (by jef):
 Replying to [comment:4 FiReSTaRT]:
 > I'm positive that toggling editing, opening the attribute table and
 switching between highlighted features (with editing on) worked A LOT
 faster on 0.11 and without the huge CPU usage.
 Just to be clear.  You did use the same dataset (ie. polygons with lots of
 points.  for example in the above dataset Texas has ~60000 points).
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1472#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
