[QGIS-trac] [Quantum GIS] #1487: QGIS fails to recognise Shapefile projection
Quantum GIS qgis at qgis.org
Thu Jan 15 13:27:57 EST 2009
   Reporter:  marisn                            |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.0.1
  Component:  Projection Support                |            Version:  1.0.0
   Keywords:                                    |   Platform_version:
   Platform:  Gentoo                            |           Must_fix:  No
Status_info:  0                                 |
 When loading shapefile with defined projection into QGIS 1.0.0 pr2, it
 shows up as layer without coordinate information (assigned default one).
 ogrinfo reports projection info just fine. Shapefile is created with
 Phyton + OGR and as SRS is used EPSG:3059
 ogrinfo -ro -so bbox_3059.shp bbox_3059
 INFO: Open of `bbox_3059.shp'
       using driver `ESRI Shapefile' successful.
 Layer name: bbox_3059
 Geometry: Polygon
 Feature Count: 240
 Extent: (28.110982, 56.323566) - (1050169.240520, 524386.627352)
 Layer SRS WKT:
 PROJCS["LKS92 / Latvia TM",
     GEOGCS["LKS92",
         DATUM["Latvia_1992",
             SPHEROID["GRS_1980",6378137,298.257222101]],
         PRIMEM["Greenwich",0],
         UNIT["Degree",0.017453292519943295]],
     PROJECTION["Transverse_Mercator"],
     PARAMETER["latitude_of_origin",0],
     PARAMETER["central_meridian",24],
     PARAMETER["scale_factor",0.9996],
     PARAMETER["false_easting",500000],
     PARAMETER["false_northing",-6000000],
     UNIT["Meter",1]]
 FID: Real (11.0)
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1487>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
