[QGIS-trac] [Quantum GIS] #1515: wms layer is added even if the the request fails
Quantum GIS qgis at qgis.org
Mon Jan 26 14:52:34 EST 2009
   Reporter:  lutra                             |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.0.1
  Component:  WMS                               |            Version:  1.0.0
   Keywords:                                    |   Platform_version:  Ubuntu 8.10 32 bit
   Platform:  Debian                            |           Must_fix:  No
Status_info:  1                                 |
 When a WMS layer is added and the requests fails, the layer is added
 anyway in the legend. The result is that if the layer is not removed by
 hand from the legend, any action (zoom, pan, add/remove other layers) will
 produce the error shown when the initial request failed.
 If the wms layer cannot be retrieved it should not be added to the legend.
 I noticed this behavior when I mistakenly used the wrong URL while adding
 a new wms server connection:
 I used
 http://mapas.igeo.pt/igp/Capabilities/wms_CRIF_GetCapabilities.xml
 instead of
 http://mapas.igeo.pt/wms/crif2008
 The first URL gives a list of layers but a error is returned when you try
 to add them, still they are added to the legend.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1515>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
