[QGIS-trac] Re: [Quantum GIS] #1565: grass vector attributes are
not available in qgis
Quantum GIS
qgis at qgis.org
Sat Mar 7 17:55:23 EST 2009
#1565: grass vector attributes are not available in qgis
Reporter: marchesinivan | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.0.2
Component: GRASS | Version: 1.0.0
Resolution: | Keywords: vector, attributes, grass
Platform_version: debian testing | Platform: Debian
Must_fix: Yes | Status_info: 0
Comment (by niccolo):
I loaded the '''spearfish60''' mapset, added the '''landcover''' vector
layer, clicked on "Open Attribute Table": I see a three columns table:
'''id''', '''cat''', '''label'''.
I can also use the label field as a label on the map. The same with other
vector layers.
If I understand the bug report, this means that the error here does not
appear.
Check packages installed on your system, may be the upgrade was not
perfect and you have some leftover. Purge them with dpkg --purge. I have
the following packages on my Debian Lenny box:
* libqgis1
* python-qgis
* qgis
* qgis-common
* qgis-plugin-grass
* qgis-plugin-grass-common
All of them from 1.0.1~gfossit20090217-1 build
* grass 6.3.0.1gfossit20090217-1
* gdal-bin 1.5.2-3
* libgdal1-1.5.0 1.5.2-3
* libgdal1-1.5.0-grass 1.5.2-1
* python-gdal 1.5.2-3
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1565#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
