[QGIS-trac] Re: [Quantum GIS] #2154: Not correctly creating (or reading) proj file for CRS for EPSG 2193
Quantum GIS qgis at qgis.org
Fri Nov 27 04:40:41 EST 2009
        Reporter:  mesajs                            |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.4.0
       Component:  Projection Support                |       Version:  HEAD
      Resolution:                                    |      Keywords:  CRS
Platform_version:  Vista 64                          |      Platform:  Windows
        Must_fix:  No                                |   Status_info:  0
Comment (by mesajs):
 Initial test was using R12236.
 Have just downloaded R12266 and problem is still there. No towgs84
 parameter appears in the .prj file, and the layer still loads as a user
 defined projection.
 Tony
 PS. Tried manually editing the .prj file, adding the towgs84 parameter.
 The layer then correctly shows in QGIS as EPSG 2193 (NZGD2000/NZTM2000).
 So problem is in the creation of the .prj file.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2154#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
