[QGIS-trac] Re: [Quantum GIS] #2154: Not correctly creating (or
reading) proj file for CRS for EPSG 2193
Quantum GIS
qgis at qgis.org
Fri Nov 27 06:37:01 EST 2009
#2154: Not correctly creating (or reading) proj file for CRS for EPSG 2193
Reporter: mesajs | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.4.0
Component: Projection Support | Version: HEAD
Resolution: | Keywords: CRS
Platform_version: Vista 64 | Platform: Windows
Must_fix: No | Status_info: 0
Comment (by cmoe):
Hi Tony
please try to give a full shapefile name with extension, eg.
"myshapefile.shp" when asked in the dialog and report back.
For me I works this way. I does not work, if I only give the name
("myshapefile"). But I work under linux and not vista.
Jürgen: does the uri have an ".shp" ending when not using the name with
extension? If not, this may be the problem as createEmtpyDataSource() in
QgsOgrProvider tests for the last four characters of the uri and only then
the prj files is overwritten.
regads
Cédric
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2154#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
