[QGIS-trac] Re: [Quantum GIS] #2154: Not correctly creating (or reading) proj file for CRS for EPSG 2193
Quantum GIS qgis at qgis.org
Fri Nov 27 07:50:36 EST 2009
        Reporter:  mesajs                            |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.4.0
       Component:  Projection Support                |       Version:  HEAD
      Resolution:                                    |      Keywords:  CRS
Platform_version:  Vista 64                          |      Platform:  Windows
        Must_fix:  No                                |   Status_info:  0
Comment (by cmoe):
 Replying to [comment:3 warmerdam]:
 > This is similar to what QGIS used as a PROJ.4 string, except without the
 +towgs84 string indicating that the datum should be considered equivelent
 to WGS84.  I'm not sure why that is missing, perhaps something is older in
 your QGIS environment.
 Hi Frank
 AFAIK, Qgis uses QGR to create new vectorfiles/shapefiles by calling
 OGR_DS_CreateLayer. The ESRI Shapefile driver of OGR then strips out the
 towgs84 parameter in his morphToESRI() method. At least that's what I
 understand.
 regards
 Cédric
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2154#comment:7>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
