[QGIS-trac] Re: [Quantum GIS] #963: The project Save? dialog does not appear when expected.
Quantum GIS qgis at qgis.org
Sun Nov 29 04:57:38 EST 2009
        Reporter:  smizuno                           |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.4.0
       Component:  Project Loading / Saving          |       Version:  HEAD
      Resolution:                                    |      Keywords:  save dialog
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Changes (by lutra):
  * type:  defect => bug
  * milestone:  Version 1.0.3 => Version 1.4.0
Comment:
 Tested now on r12279: adding a layer now seems to work. If you try close
 qgis it ask you if you want to save the changes.
 Removing a layer still doesn't work as expected: you can remove a layer
 from a just saved project and then close qgis. No question will pop up
 asking to save the project.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/963#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
