[QGIS-trac] Re: [Quantum GIS] #1977: spatialite layers disappear
when enabling reprojection
Quantum GIS
qgis at qgis.org
Sun Nov 29 05:34:06 EST 2009
#1977: spatialite layers disappear when enabling reprojection
Reporter: pcav | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.4.0
Component: Data Provider | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 0
Changes (by lutra):
* priority: minor: annoyance => major: does not work as expected
* platform: Debian => All
* must_fix: No => Yes
Comment:
This is still confirmed and I (only) now noticed that this is the same
identical problem that we have now also with shapefiles (until a few days
ago with shapefiles worked ok). See #2148.
Resuming:
Add a layer '''then''' enable OTFR and choose a crs for the project.
1) If the layer crs is equal to the project crs, than is all ok
2) if the layer crs is different from the project crs than it doesn't show
in map canvas
You may also want to try this:
Open a new project, enable OTFR, choose a crs for project and '''then'''
add a layer
1) Even if the project crs is different from the layer crs it seems to
work fine, but...
2) If you then choose another crs for the project (different from the
layer crs), then again the layer will not show in map canvas.
I will test also postgis and then repost back.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1977#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
