[QGIS-trac] Re: [Quantum GIS] #3270: NEW Symbology - Transparent
polygons are not transparent when selected
Quantum GIS
qgis at qgis.org
Mon Dec 13 04:28:46 EST 2010
#3270: NEW Symbology - Transparent polygons are not transparent when selected
Reporter: pinux | Owner: wonder
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: Symbology | Version: Trunk
Keywords: | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
Comment(by pinux):
Replying to [comment:2 lutra]:
> How other GIS software behave?
In Arcmap 9.3 a selected object remain transparent and with the same color
of an unselected object only the outline is highlighted.[[BR]]
I think that it should be transparent, let's assume that I want to edit a
layer and I need to have it transparent so that I can see the layers under
it. Then I want to cut 1 object in 2, I select the object that I want to
cut with the tool "Split features" (I selected it because I want to cut
only that object), then i start to cut that object but I just can't see
what is under the selected object.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3270#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
