[QGIS-trac] Re: [Quantum GIS] #3270: NEW Symbology - Transparent polygons are not transparent when selected
Quantum GIS qgis at qgis.org
Mon Dec 13 10:46:09 EST 2010
        Reporter:  pinux                             |         Owner:  wonder
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.7.0
       Component:  Symbology                         |       Version:  Trunk
      Resolution:  wontfix                           |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Changes (by lutra):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 Good news, I didn't even realized that now in trunk (maybe also in 1.6)
 you can set the transparency level of the selection color. You can do it
 in both the general options and in the project properties. When you choose
 the selection color you have also a "alpha channel" spinner.
 This way, in the new symbology, you can see transparent as you want a
 selection of a 100% transparent geometry.
 I believe that this solves your problem. Reopen if necessary.
 > In Arcmap 9.3 a selected object remain transparent and with the same
 color of an unselected object only the outline is highlighted.[[BR]]
 > I think that it should be transparent, let's assume that I want to edit
 a layer and I need to have it transparent so that I can see the layers
 under it. Then I want to cut 1 object in 2, I select the object that I
 want to cut with the tool "Split features" (I selected it because I want
 to cut only that object), then i start to cut that object but I just can't
 see what is under the selected object.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3270#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
