[QGIS-trac] Re: [Quantum GIS] #3345: Bug: Spacing is messed up in composer labels
Quantum GIS qgis at qgis.org
Tue Dec 28 05:35:03 EST 2010
   Reporter:  Alister                           |              Owner:  mhugent
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.7.0
  Component:  Printing                          |            Version:  Trunk
   Keywords:  Print, Composer labels, font      |   Platform_version:  XP
   Platform:  Windows                           |           Must_fix:  No
Status_info:  0                                 |
Comment(by mhugent):
 I tested it with the Qt pdf export and the system pdf printer on ubuntu.
 Both produce output as expected. Don't know if it might be a problem in
 the gdi print engine of Qt.
 The Qt pdf export should give the same results on all platforms. It does
 however rasterize the text (I guess that's why you use a gdi pdf printer
 instead).
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3345#comment:7>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
