[QGIS-trac] [Quantum GIS] #3375: print composer: create mapbooks
Quantum GIS
qgis at qgis.org
Wed Dec 29 13:22:24 EST 2010
Reporter: lutra | Owner: mhugent
Type: enhancement | Status: new
Priority: minor: annoyance | Milestone: Version 1.7.0
Component: Build/Install | Version: Trunk
Keywords: | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
I don't know if the following suggestion is better suited for a composer
enhancement or a for a plugin suggestion, I'll leave this to you (Marco),
in case close this ticket and I'll open a "plugin idea" one on the plugin
trac.
Regularly it pops out the question/request by someone asking about if QGIS
can create mapbooks.
I used to create mapbooks years ago (on proprietary software), when
working on the field, and I know that this feature can be really useful.
The idea is the following: create a layout then choose a scale, a paper
size and orientation and a % of overlapping.
A mapbook tool will then create many layouts (pdf files, or directly to
the printer) by fitting the layout into the page size. Each layout will
show a portion -at the chosen scale- of the original layout map and each
layout map will overlap the near ones with the chosen %.
A "overview" sheet should be also produced to show all the mapbook
"pieces" (usually numbered).
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3375>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
