[QGIS-trac] Re: [Quantum GIS] #3376: CMake cannot find GDAL or GEOS
Quantum GIS
qgis at qgis.org
Thu Dec 30 18:17:50 EST 2010
Reporter: sharpie | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: Build/Install | Version: 1.6.0
Keywords: cmake osx | Platform_version:
Platform: OS X | Must_fix: No
Status_info: 0 |
Comment(by sharpie):
Adding FORCE to SET worked.
Additionally, I noticed that many of the SET commands are of the form:
SET( <variable> <value> CACHE STRING INTERNAL)
This looks like an attempt to set the <type> of the variable to both
STRING and INTERNAL. According to cmake --help-command SET:
The value for <type> may be one of
FILEPATH = File chooser dialog.
PATH = Directory chooser dialog.
STRING = Arbitrary string.
BOOL = Boolean ON/OFF checkbox.
INTERNAL = No GUI entry (used for persistent variables).
I don't know if specifying two types is causing any problems, but it is
probably not working as intended. For the two APPLE SET commands, I
replaced STRING INTERNAL with FILEPATH "A Description" FORCE.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3376#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
