[QGIS-trac] Re: [Quantum GIS] #2078: [Windows] adding a GRASS
 raster created with r.external crashes QGIS
    Quantum GIS
    qgis at qgis.org
    Fri Feb  5 10:36:57 EST 2010
#2078: [Windows] adding a GRASS raster created with r.external crashes QGIS
        Reporter:  pcav                                       |         Owner:  rugginoso
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.5.0
       Component:  GRASS                                      |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  Windows
        Must_fix:  No                                         |   Status_info:  0
Comment (by lutra):
 Hi again,
 under xp I removed, cleaned and reinstalled everything. In my case the
 result is the same as above, and so is under Vista 32bit (I made a fresh
 install of the OS).
 In both cases the windows OS are installed in virtual machines.
 To test I used the "landcover.img" raster in the qgis demo dataset.
 Under linux is ok.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2078#comment:9>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
